Have 1990 Commodore Regal w/ 454 and Volvo Penta IO. Idles fine, runs fine at Low RPM and runs fine at high RPM with no load (in Nuetral). When under load though once i get up to about 3000 RPM engine rapidly looses power (rpm). Almost like its starving for fuel??? Check ignition dist cap and rotor and replaced as it was a bit worn, retry and same symptoms. It has a holley 4 barrel carb and not sure if an adjustment might be in order?
other symptoms include: at higher RPM only (3000) (under load) get quit a bit of white smoke from exhaust.
Thanks in advance for any feedback
