Going from a Honda 50 to a Yamaha 70 four stroke
Status
Not open for further replies.
fish7777
Hello all,
I have a Honda 50 four-stroke on a Stinger 160 tunnel hull, which weighs about 1500-1800 lbs, depending on loading. It currently generates 5500 rpm's at WOT and a top GPS speed of 30.2 lightly loaded in perfect conditions, with an 11.1x14 three-blade aluminum prop. With 2 people and a full load, I can hit 27mph.
I'm repowering to a Yamaha 70 four stroke. I'm hoping to get better top-end and cruising speed; I don't care too much about quick hole shot. Any thoughts on initial prop composition and pitch to try? I thought I'd try a 17 or 19 pitch aluminum 3-blade then maybe switch to a SS 3-blade after determining the best pitch. Seems like the 19" pitch would work OK with the bigger motor?
Any input from the prop wizards here would be appreciated.
fish7777
Hi Wes, thanks for the reply. I did the yamaha prop selector before I posted. Unless I'm using it wrong, that tool isn't applicable when repowering a boat because it asks for the current pitch and rpm of the Yamaha F70, which I don't have yet. The tool would be good after I repower, but I'm looking for a pitch to begin with on the F70.
ahicks
This is generally a best guess scenario. I like the 17" alum. plan. Done early enough in season, if it were too far off you could have it re-pitched to bring it in line with your target rpm. much cheaper than buying another prop.
As far as target rpm, I've messed with quite a few mid range Honda's (40-90hp) and found that although they are fine at max rpm, backing off 4-500 leaves you with no loss of speed, and an engine that doesn't sound near as "busy" as an engine run at max rated. FWIW, -Al
WesNewell
For reference only
  • Boat type: Bass
  • Usage: Top Speed/0 ft
  • Engine Manufacturer:
    Mercury
  • Engine Type: Outboard
  • Engine Year: 2018
  • Number of Engines: One
  • Engine Family: FourStroke
  • Engine: 60 EFI 4cyl (995cc)
  • Drive / Gear Case: 40-60 HP FourStroke Command Thrust, 2.33 Ratio
[h=3]Details[/h]
  • Calculated Pitch: 19.12
  • Calculated Weight with engine(s): 1,566.40 lbs
  • Calculated Engine RPM: 5,875
  • Calculated Boat Speed: 41.23 mph
Faztbullet
Does it have the big or small gearcase???? Prop diameter will make a difference.
fish7777
Thanks everyone for your help. The Mercury prop selector tool was helpful.
Faztbullet, I think the F70 only has one size for gearcase? The prop diameter generally ranges from 13" to 14", depending on pitch.
MattFL
Master Chief Petty Officer
Did you make the switch to the F70, and how did you like it? I've also got a 50HP Honda (20+ yrs in service now) and made the mistake of looking at new motors, lol. On paper the F70 looks like a great upgrade from the 50HP Honda, but I would love to hear real life experiences from anyone who has made the switch.
GA_Boater
He hasn't been here since his last visit on 12/16/18 - Over 4 months.
Closed.
Status
