going from small block to big block
jaxnjil
Re: going from small block to big block
well i cant sell the boat. i just finished setting it up the way i like it. a fishing machine with my boys. and a overnighter with the family. i guess i will have to do a complete repower. will the bravo 1 work or would the more desirable bravo3 be better. will the transom assembly for a bravo work on both types?
thanks for all the answers, i seen on my transom that the alpha 1 gen 2 should only be used up to 260hp. so either way that needs to be changed out!
yes they both take the same transom assembly.
i cant help thinking a good strong 350,a 4 blade prop, and a pair of bennet trim tabs would get you going.
i havent figured the final bill out but big stuff came to around $7500 to swap my alpha to a b3. i started with a 454 alpha.
