Going rates for mechanical diagnostic
Jimmy310
What is the going rate or a fair price to pay an outboard mechanic for a complete outboard diagnostic check/test?
I had a problem I think is overheating and wanted to make sure I dont get taken for a ride.
Second problem is the throttle control makes the boat go forward in Neutral.
Third I have no reverse. I throttle back and the boat goes forward. :eek:
Help me out with suggestions or PM me.
Thank you,
Jimmy310
Fuzzytbay
Re: Going rates for mechanical diagnostic
The bottom end has been taken off, and not put back on correctly. The shifting Dog is upside down, the bottom end needs to come off, and realign the shifter. Up here in Canada the cost would be about 150.00 bucks including a new water pump impeller at a dealer, maybe 75.00 at a private shop.
Ydnar84
Thank you,
Jimmy310
Not sure on a price for a diagonstics, some shops will do one for free for good buisness and get you for the work to get done and some will just flat out try and get you for 50$ just for them to look at it.
Onto your clutch thing, If seems that you need to re-align your cluch throttle cable on your engine (The bottom one of the two cables). I know on Mercury Optimax, you have to adjust a bolt until it is perfect alinged with a "N" (as in Neutral) it seems as if the nut got lose and and your clutch cable shifted to "F" (Forward) and is why your boat is going forward when it should be in neutral and also explains no reverse since your reverse is now going to be Neutral most likly. Check that out before anything.
Over heating things can be anything, find a friend with a DDT (Digital Diagnostic Tool) and run an automatic test, good chance it will be either a Thermostat (most common) or the water pump. Main question is when you run it on the hose is if you get a good discharge or not. IF you run hot and have good water discharge it's like 80% chance of being the Thermostat.
ENSIGN
Here in baltimore your looking at $80.00 an hour,unless YOU WORKED ON IT FIRST!!!!
Fuzzytbay
The motor is I think a 1967, 850, not even close to new models. Its the clutch dog, very common bottom end symptom issue for those old inline six's.
KurtG
$75 an hour here, most have 1, but some have 2 hour minimum charges.
Ydnar84
I didn't see any specs on his post so i rendered help for the newer motors which that's what i know.
Jimmy310
Here are the specs for the outboard.
1967 Mercury 650 SL 4 cylinder, 65 HP
dkonrai
here in norcal, the going rate is 125.00 hour.
