brooksville_rebel
Thread starter- Joined
- Aug 12, 2011
- 240
Last two weekend's out there seems to have been a lot of grass floating on top of the water. Wife says its from the shrimpers dragging their nets. This is in the Gulf.
Boat is a 24ft pontoon with 40hp.
We will be going along when suddenly the engine or prop will whine and lose juice. We have to "pull over", shut down the engine, tilt it up and normally watch a glob of grass float away. Sometimes I have to reach down and pull some off the lower unit. Restart and were are good till the next instance which can be a few minutes later at times. I think it happens more when we are full WOT then say half WOT along. Top end for us is about 10-12 knots.
I don't see others having this issue out there so not sure why we do and why so often.
Is it the grass or the start of a lower unit problem ?
Engine issue ?
Really the grass build up ? If so is there a quicker/simplier way to clear it ? Its annoying as hell especially when in the channel on the way in and boats flying up our 6.
Thanks
Mark
Engine issue ?
Thanks
Mark
