bigblock454
Thread starter- Joined
- Apr 28, 2008
- 206
Hey folks! I've posted my new purchase in my sig, and have a few other little posts floating around here, getting some good help/feedback. Sooo.... I'm getting ready to rebuild my gimbal assembly, transom assembly, whatever that whole mess is called. I got in the mail recently all the following: Transom rebuild kit from sierra, including bellows, gimbal bearing, gaskets, hoses, etc. Got a lower shift cable (with another shift cable bellow), bellows adhesive. Got QS tilt/trim send units. I also got an exhaust "tube" separate from the exhaust bellow that came with the kit. I hear they are easier to install, and I don't mind (a little) throatier of a sound, if there is indeed a difference. Got my Moellers Zinc Chromate and gloss black acrylic urethane (got the latter from Summit Racing). Got some "perfect seal". I think that's about it. Also ordered a QS water impeller kit, but that's not in yet. A buddy of mine who's expertise is boat repair, has my lower unit at this time, and is going through it to make sure she's good to go. Anyway... I'm ready to get my transom assy apart, so I can clean, strip, and repaint everything before I attempt to get her back together. I have the hinge pin removal tool (pins nicely loosened now), and the shift cable special socket. I've read quite a bit on the subject (including the factory manual), but always willing to learn from the more experienced! I will post a pic here of my transom assembly in it's current state to better show the extent of what I call "moderate" corrosion. I bought a drill mounted paint/rust stripper wheel. But figured I'd ask before using something maybe way more aggressive than needed. Thanks for any pointers, tips and help! Norm
