going to change impeller and need help! please.
jonnymarquis
ok so i have a 1977 70 hp evinrude here is a blow up diagram http://shop2.evinrude.com/Index.aspx?s1=5du70qtakej89omevs3hf98uk2&catalog_id=0&siteid=1
i cant just find the impeller kit. and cant find the housing anywhere. but out of this diagram what all parts do i need to change it. and is the a gasket that goes where the gearcase attaches to the exhaust housing. first time changing impeller but i think i can handle it. thank you guys.
its a 1977 70 hp evinrude 70773s 20" transom
jonnymarquis
Re: going to change impeller and need help! please.
yes cofe ty that is what i needed the kit. the only thing it said that it was without housing should i be worried about that? if not ill just wait till it gets here and cross that bridge. ty again!
Cofe
The housing is usually ok, unless the motor was severely overheated. If you need any more help just post. Lots of people here to help.
