Going to Paint Your Outdrive? - Read This First
mthieme
Still thumbing through manuals and ran across this tidbit about painting outdrives....
Using copper based paint will accelerate galvanic corrosion.
Vinyl-Butyl base anti-fouling paint is recommended (by OMC).
Do not use graphite based anti-fouling paint.
Of course, we all know never, never, never paint your zincs.
F14CRAZY
Ensign
Re: Going to Paint Your Outdrive? - Read This First
does rustoleum count?
chiefalen
Ha the kids rule.
Ayuh,...
I always have used Rustolium,...
When it was a trailerboat,... I'd shoot it a couple times a year...
Now, as a dockboat,... Once a season,.. Some seasons....
It's lookin' alittle Rough this year...
I'll probably knock the alge,+ zebra mussels off it this spring,+ reshoot it again...
THE BEEF
Question?
I converted my 800 stringer to full mechanical shift.I gave it a paint job that looked great!
I used OMC primer and OMC white paint.
After the season my outdrive looked like it had small poxs. Blisters all over,
Looks like S***.
Any Ideas?
Beef
chiefalen
I use the professional rustoleum, in the silver can. Black.
Don S
I have always used RustOlem on my own personal drives. May take longer to dry, but it sure lasts better than any of the other rattle-can paints. Readily available, and inexpensive. Gloss black when I had a Mercruiser, Smoke gray for Volvo.
In Merc's service manual for the Alpha I Gen II drives there are procedures outlined for painting the drives to factory specs (or close to it) if you are really into painting by the book, here is a copy and paste from the service manual.
The following procedure should be used in refinishing gear housings. This procedure will
provide the most durable paint system available in the field. The materials recommended
are of high quality and approximate marine requirements. The following procedure will
provide a repaint job that compares with a properly applied factory paint finish. It is
recommended that the listed materials be purchased from a local Ditzler Automotive Finish
Supply Outlet. The minimum package quantity of each material shown is sufficient to
refinish several gear housings.
Procedure:
1. Wash gear housing with a muriatic acid base cleaner to remove any type of marine
growth, and rinse with water, if necessary.
2. Wash gear housing with soap and water, then rinse.
3. Sand blistered area with 3M 180 grit sandpaper or P180 Gold Film Disc to remove paint
blisters only. Feather edge all broken paint edges.
4. Clean gear housing thoroughly with (DX-330) wax and grease remover.
5. Spot repair surfaces where bare metal is exposed with (DX-503) alodine treatment.
IMPORTANT: Do not use any type of aerosol spray paints as the paint will not properly
adhere to the surface nor will the coating be sufficiently thick to resist future paint
blistering.
6. Mix epoxy chromate primer (DP-40) with equal part catalyst (DP-401) per
manufacturers instructions, allowing proper induction period for permeation of the
epoxy primer and catalyst.
IMPORTANT: Do not paint sacrificial zinc trim tab or zinc anode.
7. Cut out a cardboard ?plug? for trim pump pocket to keep paint off of mating surface to
maintain good continuity circuitry between trim tab and gear housing.
8. Allow a minimum of one hour drying time and no more than one week before top coating
assemblies.
9. Use Ditzler Urethane DU9000 for Mercury Black and DU33414M for Sea Ray White.
Catalyze the colors with Ditzler DU5 catalyst mixed 1:1 ratio. Reduce with solvents per
Ditzler label.
CAUTION
Be sure to comply with instructions on the label for ventilation and respirators.
Using a spray gun, apply one half to one mil even thickness. Let dry, flash off for
five minutes and apply another even coat of one half to one mil film thickness. This
urethane paint will dry to the touch in a matter of hours, but will remain sensitive
to scratches and abrasions for a few days.
10. The type of spray gun used will determine the proper reduction ratio of the paint.
arks
When I had a I/O, I had my neighbor (who runs a body shop) paint my outdrive and transom plate "Mercruiser Hi Performance Blue". He used a 2 part paint similar to Imron and it looked great.
I blew up that outdrive 2 months later.....:mad:
WizeOne
Looked extra sharp Arks. Why did it blow up with all that fancy cooling on it?
chiefalen
He probably over powered the drive with a souped up motor. The need for speed.
25 on a choppy bay is all my back can take. Maybe 30-35 if i got to get out of the way of something, than back to 25.
arks
Sorry to disappoint chiefalen, but I only had 260HP pushing it. Alphas can take 300. The REAL reason it went was because the #%@* shop who rebuilt it did a crappy job. After spending all that $$$$$$ I decided it was best to just bite the bullet and buy a brand new outdrive. Expensive, but it was a "lesson learned".
That incident is one of the reasons I now have an inboard boat.
Don S
Keep one thing in mind. Alpha style drives are NOT Hi Performance drives by any stretch of the imagination. Never was, never will be, no matter what color they are painted.
