crazy charlie
Thread starter- Joined
- May 22, 2003
- 5,753
Im transported home for the season.Twin 5.0 mercruisers with alpha one drives 1988.
Serviced water pump on stbd drive preseason.Only put a few hours this season with no issues with cooling so I am sure water pump service went well. My slip is muddy at low tide and after idling with drives 3/4 raised ,water flow to p.steering cooler stopped and engine temp raised .Hooked up muffs in my yard yesterday and same issue .Pressure washed intake screens on drive. Water exiting thru prop hub.My guess is water tube in the top of water pump is clogged with mud.Will find out when I pull the drive next week.I also pulled ps cooler hose at the stat and put garden hose in to reverse water flow thinking possible ps cooler was clogged but that didn't seem to be the case.Will keep posted. Anyone want to take a guess where the clog is? I have not had a bad impeller in over 20 years but it wouldn't be a 1st. Charlie
