nola mike
- Joined
- Apr 22, 2009
- 5,816
Well, good news first:
Got the boat in the water the other day, and was running pretty well overall. Flushed coolant, changed oil, painted/cleaned exhaust manifold/riser and replaced gaskets/flapper. Got an electric polisher and went to town on the gelcoat with some cleaner and wax, and oiled up the teak, vacuumed--came out looking incredible. Can't believe how good the outside looks.
Bad news:
1. hesitation when accelerated hard from low speed is worse this year. carb accelerator looks ok; noticed my timing was pretty far off. i'll play with the dwell next weekend and give it a proper tune up before i blame the carb.
2. my "new" outdrive is leaking--after about 5-10 miles in the water, I have some milky oil. i kind of had a feeling that was coming (http://forums.iboats.com/showthread.php?t=378457), you were right chris. i did get some water in the bilge before i noticed a leaking exhaust elbow, so i'm hoping that's where it came from, but i'm pessimistic about that. thinking about biting the bullet and buying and sei drive while i repair this one. i'm guessing that a) there's another leak aside from the input drive shaft, and b) a vacuum test is more important than a leak test
Bad news:
