Gooey bellows
Rick Stephens
'90 3.0 Alpha 1 Gen 1. Bought boat mid summer, took it fishing a bunch. Everything worked fine, ran like a clock. I am now going through everything to both winterize and find out what is marginal. My first time inside this outdrive. Been reading this site for a while, and have all the manuals.
Drained the outdrive, oil was minimally tainted with a teensy bit color. Previous owner stated his mechanic had replaced a seal in the spring since he saw a little water in the gear oil. He did not remember or know which seal. The minimal amount now could be because of leftover past contamination or new contamination, no way to know. Time for pressure testing.
Pulled the leg - lots of light brown goo - 1/2 inch - water mixed with oil or grease in the bellows. Smells more like grease than gear oil, but frankly, could be either or both. Gimbal bearing has some rough spots (yeah, big surprise, right). There's enough rust in the nooks and crannies of the CV joint that I suspect this has been going on for a while.
Bell housing gasket was glued onto bell housing side. But looked ok, not pushed out anywhere or missing any parts.
Bellows is soft and looks great.
I have 6 hours with the leg pressurized to 12 pounds and still holding. I even did this in a water trough to be certain. So far, no bubbles and no leak down at all. Been rotating the input shaft and gear shift occasionally.
From what I have read the input shaft seal isn't all that good at keeping water out of the gear case. So that may have been the source of the contaminants in the lube.
If I pass overnight pressure test, then I plan on splitting the cases and replacing the impeller. Other than that, I am planning to try and use it next spring without going much deeper.
Questions come in on what to do to the bell housing/bellows. With this a new to me boat, I'd like to do this right.
1) Just go ahead and replace the bellows? (is this best an OEM part?)
2) shift bellows and exhaust at same time?
3) since already in there, intake water line?
4) ujoints seem fine - but they were definitely in the goo. To get those you have to pull the ujoint bearing retainer? Does the rolling torque need re-torquing as well or jest leave it be? It is probably going to be lower than spec after how ever many years of use. If I have to redo the torquing then I'll probably replace that top seal while I am there.
5) there is definitely a little bit of pitting on the drive shaft where the grease seal in front of the gimbal bearing rides. Not much, but a little. Is this cause to replace that front shaft? Hard to tell where the seal rides, the long term pitting may not be the same place. A little emory clothe to smooth it? Decent seal here might keep the boat dryish if a bellows goes south :^) That shaft is spendy. Love to keep it if possible. I'll post pictures if that will help.
My list is getting longish on things might need doing. Is mostly relief that the outdrive appears to be in a lot better shape than it might have been. The possibilities seemed endless when I did a fairly perfunctory once over before buying it - I paid for it while motoring around in it, so at a minimum I knew it functioned perfectly and sounded good. Now's the time to figure out what all needs doing to keep it that way.
Also, trying to figure out what all should be OEM parts. My reading has shown a tendency towards OEM seals and some gaskets, most of the 'sets' available online are probably after market. What is important to make certain of OEM?
Thanks for your assistance and thoughts.
Rick
GA_Boater
Re: Gooey bellows
I'm not going to give you any advice because what you're asking is beyond my limited M/C knowledge. But the Gurus will be asking for the serial numbers because a year doesn't really mean much. The S/N ID's what parts and advice is given. Good luck and hope it's not too expensive for you.
thumpar
Re: Gooey bellows
Can you tell if bellows adhesive was used on the last bellows install?
achris
More fish than mountain goat
Re: Gooey bellows
HI Rick, Yeah, GA got it right, serial number serial number serial number.. The three most important parts of the job... To answer as you asked...
1, 2 and 3... OEM is the best, and I would certainly be doing all the bellows and the water hose, and the gimbal bearing... Merc genuine are the only parts I use in that area. And Merc do a 'transom seal kit' with all those parts in... Give us a serial number and we can give you the right kit number. While you are in there, check that you have the updated style shift shaft bushing in the bell-housing, and that the shift cable doesn't need replacing.
4. Replacing the unis does NOT require the removal of the bearings and drive gear from the housing. They can be done with it all still assembled.
5. That shaft normally cops a hiding when water gets around. Never had to replace one for pitting yet...
Now, serial number... You know where to look for it? If not, click HERE.
Chris......
stonyloam
Re: Gooey bellows
The "goo" is probably excess gimbal bearing grease mixed with a little water.
1) Yes. Yes!!
2) Shift: Yes, Exhaust, if it is in decent shape don't bother (save the money for the OEM bellows).
3) If the water line is not cracked it should be OK, change it if you like. It is a PITA to change, if you do be very careful not to kink it.
4) U-joints ?? may be OK, are they rusty?
5) Pitting on the drive shaft is not important, that seal in front of the gimbal bearing doesn't do much, mostly keeps gimbal bearing grease out of the engine compartment.
You might consider doing the lower shift cable while you are at it, a lot easier now than later.
Check your outdrive trim limit switch, now is the time to change it if the wires are in poor shape.
When you do the impeller, take a real good look at the metal inside, if it is not perfectly smooth, a good time to change the housing too.
OEM for everything! All just IMHO
Rick Stephens
Re: Gooey bellows
Well, I keep saving my serial numbers as a sig file and it doesn't show up. I'll try something else.
17 Foot '90 Bluewater with a Gen 1 Alpha 1 3.0 Merc. Converted to my Fishing Boat!
Eng Serial 0C656718
Tran 0C787939
Drive 0C827577
thumpar
Re: Gooey bellows
1) Yes. Yes!!
When I went to do my transom seal with with water hose I kept reading it was hard to get it on. It turned out to be the easiest part. I put one end of the hose in boiling water (not touching the bottom) for a couple minutes. It slid right on. I let is cool and then bent it down the side of the gimbal housing.
GA_Boater
Re: Gooey bellows
The S/N's are showing in your sig. Rick.
Rick Stephens
Re: Gooey bellows
That makes perfect sense. Seems like the plastic section through the transom would be the likeliest place for a failure, not the hose.
Thanks!
Rick
achris
Re: Gooey bellows
Eng Serial 0C656718
Tran 0C787939
Drive 0C827577
Showed up on this one... :noidea:
The transom seal kit you need is 30-803097T1.
Rick Stephens
Re: Gooey bellows
Yeah, showed up on the new post. I was thinking it would show in the original post. I run a forum on different software (vBulletin) and it would change for all my posts when I update something.
Rick Stephens
Re: Gooey bellows
Thank you. That is what I will use.
And I think I like the idea of changing out the crosses. Glad to hear they can be done in place - didn't look that way, but I am getting old. Frankly, was looking forward to digging into the drive and making it perfect. Everyone's input is so valued ya'all will never know. I hate making the same old mistake when this conversation will prevent it. Thanks so much.
achris
Re: Gooey bellows
One last question. Is 47-89984T 5 the correct impeller kit?
Yes...
I had a look, and the reason your signature is not on your first post is because the check box 'Show Signature' is not checked.
You can change it or I can if you want....
Chris....
Rick Stephens
Re: Gooey bellows
Yes...
Chris....
I didn't have a signature when I made that post, so it probably didn't ask for it. I don't see a place to modify it.
Thanks for the impeller kit check. Nice some of the options we have in states for getting OEM Merc parts. Wish iBoats had them.
Rick
achris
Re: Gooey bellows
Rick
Done.
Rick Stephens
Re: Gooey bellows
Looking at the Gimbal Bearing
The OEM part appears to be sealed, states no hole. Is this appropriate and a replacement for the one with a grease hole? takes the transom grease fitting out of play.
achris
Re: Gooey bellows
That's correct. No grease hole, greased for life. BTW there's a bearing in that kit. No need to buy a separate one.
