Got 3 - 9.9's I Can't Id. Docktalk is gone
MGuckin
Feel kinda silly asking this but I can't ID these motors. I was using Docktalk. Need I say more? Link does not work anymore.<br />Tried Modelguide also, along with Brixtent.<br />All 9.9 Evinrudes.<br />Model 10EL766 SERIAL E4405715<br />MODEL E10RCNS SERIAL E0034383<br />MODEL 9922S SERIAL E06623<br />Major brain lapse here. Any ideas?
Goodoleboy
Re: Got 3 - 9.9's I Can't Id. Docktalk is gone
The E10RCNS....is a 1982. I cant find the other two model numbers.<br /><br />Good Luck!
CATransplant
The 9922S is actually a 1969 9.5 hp Evinrude, not a 9.9.<br /><br />The 10EL766, I can't find anywhere.
CATransplant
But...I'm betting that 10EL766 is a 1977 model, based on the model year sequencing.
MGuckin
9922S .. Plate says 9.9 @4500. Kinda thought it was 1 of the older detuned 15's. Runs excellent but I need the coolant line for it that goes from lower unit & up.<br /><br />Ca where did you id this motor?<br /><br />The 10EL766 is a parts motor.<br /><br />E10RCNS looks good but haven't checked it yet.<br />Got these 3 motors plus an excellent 76 35 HP Rude, with controls, today as part of a trade.<br />Thanks for the help
CATransplant
marineengines.com. <br /><br />9922 is a 1969 9.5hp model, unless the "S" designation means something. <br /><br />I don't think they made a 9.9 until 1974, actually.
MGuckin
Made em from 74 - 92. Kinda stumped me on this 1.
BoatBuoy
There's a 10EL76 - 1976 9.9hp
OBJ
Yep what BoatBuoy said and I'll bet it really is a Johnson with a' Rude cover.
MGuckin
OBJ,<br />Why do you suspect Johnny instaed of Rude?
BoatBuoy
The 10EL76 is a Johnson model number from 1976.
OBJ
Johnsons have always used a mix of letters and numbers to denote model. Early Evinrudes used just letters up until around 1930 and then went to mostly numbers using letters to denote engines built over seas. In 1980, both went to the mix of numbers and letters for model #'s. The difference being that the model number was preceded by a J or E. When OMC was supplying Tracker Boats with engines, the model number was preceded by a T and then the J or E. There was some variations but since 80', most OMC & BRP products are a mix of numbers and letters.
