Got a Free boat, need help identifying motor
Hi Guys, My uncle has given me an older boat with a mercury 650 outboard. From what I have found is it can be anywhere from a 65-74. This boat is 2 hours away, and I want to find myself a service manual for this motor before I go to pick it up. Does anybody know where I can find a pdf service manual that I can purchase for this motor? Also I was told this motor ran when parked, however it hasn't been run in 4 years. I am a forklift mechanic with motor experience, but little on the two stroke side. Any tips to help me out before I attempt to fire this guy back up would be greatly appreciated?
Thanks in Advance
Chinewalker
Going by the decals, it is a 1972 or 1973 Mercury 650 3-cylinder. VERY different from the 1971 and prior 650s, which were 4-cylinder models.
Check the Awakening A Sleeping Outboard thread in the Stickies section to help you out in getting it going...
emckelvy
If you sucessfully awake this motor, you MUST install a new impeller, and renew every year. Otherwise you're at extreme risk from cracking the block from overheating, if you lose your impeller. I've personally seen those results and they ain't pretty. Almost impossible to weld up the block after it happens, so it's cheap insurance to keep the impeller fresh.
There is also a mod to move the telltale hose from its present position to the top of the block. This keeps the inner water passages flooded all the time and eliminates the chance of having a pocket of air or "steam" at the top of the block, giving inadequate cooling to #1 cylinder and potentially cracking the block. Mercury moved the telltale on later models.
Here's some info I saved about the location of the new telltale hole:
7/8" forward of the split line between the rear water jacket and the block,
(where the gasket is). and 3/4 inch to the left of the ridge that runs fore
and aft above #1 cylinder. Use a plastic 1/8" pipe thread fitting.
Another must-do on these is to make sure the prop pitch is low enough to let the engine run up into its rpm range (around 5500 rpm at full throttle). The displacement is only about 44 cubic inches, doesn't make a lot of torque, so the engine needs to wind up to make power. If you lug this motor, you'll kill it.
All that being said, if you have a good one, they are lightweight and work well on a light boat, with good economy.
HTH & G'luck..........ed
gm280
Oh a FREE boat... I'm sure you are excited, but free boats are anything but. I get the feeling you will find this out soon. But not to discourage you, you won't be the first to get a free boat and then understand what it will take to make it water worthy again. However, you come to the absolute best place for such help and assistance. Once you do get the boat home, start taking tons of pictures and post them on here for us to see what you are dealing with. We can then offer what will need to be checked and fixed to give you the best boat possible... :thumb:
That particular motor is not in the top 10 on the hit parade.-----Many ignition parts are expensive if available.
