bob johnson
Thread starter- Joined
- Feb 25, 2009
- 4,306
i took my boat out with the new to me 115 johnson. the prop I used came off my 90 ocean pro it is a 14x17.
my tach now works( must have been an issue in the 90 hp I had)
I used my gps to mark speed. I got up to 37 mph in my Ultra Roughneck MV turning at 5300 rpms.
from talking around this rig should be in the 40 with a 115 hp on it.
it looks like I have clearance for a larger dian prop..almost an inch between the prop now and the cav plate..
so I figure I could go to 15-15.5" dia.
I would have figured I needed to go down in pitch to get this 115 hp ocean runner( 60 degree V4) up to the rpm range to run the most efficient.
wil the dia change effect the pitch I need to go to.....how much pitch change do I need to get to 5700-5800 rpms?\\boat has a 13 degree deadrise floats very shallow..it has floatation pods welded on the back and gerts on plane in seconds
the total weight my run to about 1200-1400 lbs
I have a jack plate and I adjusted it , but the highest setting before cavitation on down to standard( cavitation even with keel) there is no change in speed, but playing with trim, I gained a mile or two per hour
thanks
bob
thanks
thanks
bob
thanks
