got alot of questions and problems
huntingdeer
The boat is a 87 phantom and i just got it from someone.Motor is a 305 mercruser.It leaks water in the back where the drive is.Is it hard to fix?:grumpy:2 the motor was running anout 210 220 temp when i was running it.Is it running hot?When i cut it off it made some hissing noise.I dont know much about inbords.And the last problem the longer it ran the more it cut off.Could it be cutting off because it was running hot.Like could it have a sutoff switch if it runs hot.Im a outbored man lol i gont now much about this but got it at a good deal.
Levinz11
Re: got alot of questions and problems
Post some pics of your boat.
210 is way hot. I would start with changing the impeller and giving the engine a FULL tune up.
huntingdeer
You have a nice boat.i only have 200 in mine lol it needs a good restore.ill post pics when I get a chance.i did not run the motor over 210.yea I'm going to do a restore on the whole boat.im just trying to get ideas.
achris
More fish than mountain goat
Probably uni or shift cable bellows. Hard to fix? For me, no. For you, I have no idea.. What is your mechanical experience, and how well can you follow a factory manual?
Yes. VERY hot. Normal operating temp is around 145-165 degrees.
We call that 'steam', and it shouldn't be doing that!
No shut-off switch for overheating. Need more information on the engine, like an engine serial number, to know what you have and what we need to be telling you... (doesn't matter what the boat is, we need to know about the engine.)
Did you? If it needs heaps of work, and the parts are expensive, I think that 'good deal' just went south....
Chris.........
huntingdeer
Well compared to what boats run around here that size I did good.i have built motors before in cars but I know boats are a little diffrent.ill get the numbers here shortly.
huntingdeer
image.jpg that is the number.If someone can give me the info on it it woud be grate.
Don S
0B581047 is your serial number, model number 02003347 which is a 87 motor called a 200 in the manuals.
It is a 305 Chevy as you know, with an Alpha I outdrive.
Don S
For the overheat, I would suggest you remove the outdrive from the boat, split it and check the raw water pump. Also look into the exhaust bellows and see if you see any metal half moon shaped pieces.
Here is a couple of files to get you started. They are from the OEM manual just assembled in order so it's not so confusing.
View attachment A1 R&R.pdf View attachment A1 Impeller replace.pdf
huntingdeer
I just looked at the alfa drive and their was a few hoses with big craks.Could that make it leak in the boat?And ok ill look at the files thanks.
huntingdeer
the attachments dont work.They say contact the adminstrater.
Don S
Not sure what happened there, they worked for a while, then stopped.
I redid the links, try them again.
huntingdeer
image.jpeg hose.jpg What is the small hose called its broke.It has a cable running threw it.
Don S
That is your shift cable bellows. The cables is commonly called the lower shift cable.
achris
View attachment 197483 What is the small hose called its broke.It has a cable running threw it.
And that, my friend, is where the water is coming into the boat at the back of the engine....
And the uni joint bellows don't look too healthy either... (the big one at the top)
Ayuh,.... Looks like All the rubber pieces need changin',... I'd throw in a New lower cable, while it's apart,...
Trim, 'n tilt senders, if yer so inclined,...
huntingdeer
image.jpeg boat.jpg Im trying to find out how to find this fuel sending unit?Im looking for a part number or something.Thanks And btw my water pump was bad and so a little hose on the water outlet.
Don S
View attachment 197909 Im trying to find out how to find this fuel sending unit?Im looking for a part number or something.Thanks And btw my water pump was bad and so a little hose on the water outlet.
Post your fuel sender question over in the electrical forum. This forum is only for your engine/drive systems.
