Got into Forward, once and once only.
jmorgan87
First trip out, she didn't go into forward very smooth. At the time, it felt like I was slowing down and starting to go forward.. the video just looks like i'm drifting. I kept increasing throttle slowly and it jumped fairly hard into gear.
Rode around for a while, several 3/4 runs but never took it out of forward. Coming back to shore, popped into neutral to wait for boats to finish loading up... boat won't go into forward. Motor would rev, but never pop into gear. Could go into reverse.
I think the idle is a bit high, could this cause this?I know the gears make it hard to come out of gear, and requires the shift interruptor.. but does higher rpm make it harder to go into gear? or is this a shift cable issue?
I ended up going to the engine, and playing with the shift cables. Tried some adjustment of the rearest cable(think that's for forward).. eventually manually pulled on one cable which popped me to reverse, then manually pulled the other way and got it into forward..and came to shore.
This was the biggest concern of our trip...you can see the boat pop into gear here:
http://www.youtube.com/watch?v=B6jjbuPACfU
jmorgan87
Re: Got into Forward, once and once only.
Might of found the true underlying cause. The rod the farthest back shift cable conected to was not tightend down, infact it had quite a bit of play. You could move the cable up/down a good inche. I tightened that down, and re adjusted the shift cable. Not running you can do forward, neutral, reverse. With it racheting one direction and not spinning the other for forward/reverse and free spinning in neutral. If I read correctly, this is about as good as I can get out of water? other adjustments will probably need to be done in the water?
I think my idle comment was incorrect, I forgot but the other guy in the boat pushed the thorttle 'down' at the carb to keep the idle lower as i went into gear, it was real low at that point and no change.
any comments welcome though..I just keep looking over the videos and pics from yesterday:D first launch in years for the boat, and first launch of MY first boat, thats legally mine and in my name:D vs family.
