starcraftkid
- Joined
- Jul 5, 2010
- 238
Re: Got me a Starchief
If you stay with the same diameter, one pitch is fine but since your pushing a much larger hull, I'd got with the largest diameter prop and jump pitch accordingly.
If the diameter is the same, I'd say your going to be around 5200-5250 or so at WOT. I would say you'll see about 175-200 RPM per inch of pitch changed.
If you just wanted to gain RPM and weren't worried about speed, I'd say jump down an inch in prop size but you would most likely loose top speed that way.
Did your dealer guy have a 12" x11P for that motor? (I see they list one at MI Wheel for that motor).
Let us know what you get with the 12p prop.
