Got my motor to fire, but ...
boatingbob
I put new plugs in my 40 hp Johnson and it started right up and gets 28 mph, then I lost one cylinder, no spark, and it's not the plug. any ideas on how to fix this? please help!!!
KYHunter2
Re: Got my motor to fire, but ...
Well bob, theres several things that can cause the loss of spark.
I'd check all , grounds, wiring, plug wire, coil, etc.
You get the idea.
You'll need a manual , if you don't have one.
It shouldn't , be difficult to find your problem.
The trouble shooting procedures , in the manual, will get you there.
Bad grounds are often , the root of alot of problems.
I coat all the engine grounds with liquid tape after cleaning.
As well as all the electrical connections, that are exposed , even the solenoid and starter lugs.
And where the coils and heads meet, after bolting up, of course.
Good-Luck,
KYHunter
jtexas
what year motor?
Switch the coil leads from the powerpack from #1 to #2 and vice versa then check spark again...if the same coil still refuses to fire then replace the coil. Otherwise...depends on type of ignition.
boatingbob
jtexas said:
what year motor?
Umm it's a 1962, the plug wires go up under the recoil, The boat was working great until I shut it off at the dock then when I started it back up it would only run on 1 plug. I ordered a manual, it still hasn't arrived. Oh I also have a 1963 28 hp for parts would the ignition system on this be swapable to the 40?
KYHunter2
There are some experts on these old motors on this site.
Paul Moir, being one of them, hopefully, they'll see your thread and respond.
KYHunter
boatingbob
KYHunter
O.K. I'm gonna head out to work on the motor this morning, can anyone tell me if the ignition system parts on my 64 28hp are usable on my 62 40hp?
please help.
tmcalavy
Depends...on the size of the stator plate, flywheel, etc. Both are magneto ignitions, no electronics. Before you get into swapping, pull the top cover and maybe the recoil to gain access to flywheel. It may have a port in it so you can check/regap the points. Do that and see if spark returns. If not, time to pull the flywheel and check the connections...could be a bad or loose wire connection. Kinda sounds like that since it just dumped one cylinder/plug all of a sudden. You can pull the flywheel with a harmonic balancer puller from an auto parts store. Could also be a coil or bad points or bad condensor, only way to tell is pull the flywheel and take a look under there.
boatingbob
K thanks I'll try that, first I'll start with the grounds and work my way in.
BoatBuoy
There should be 2 black kill wires that come from under the magneto. These wires, when shorted through the ignition switch, serve to kill the motor. Either one, if shorted to ground, will prevent it's respective cylinder from firing. I'd trace those wires to make sure the insulation is intact and the wires are not shorted anywhere.
Paul Moir
Just a side note to the above advice, the entire stator plate, components and all should swap from the 28hp just fine. Also I would start with Boatbuoy's suggestions first since they're pretty easy to test and isolates the problem to under the flywheel.
boatingbob
Well seems like my issues are under the fly wheel. I'm still waiting on my manual, Is the fly wheel placement directly related to the timing? like do I have to mark the shaft and fly wheel so I know where to put it back? I don't want to pull the flywheel and then have to worry about adjusting timing.
Paul Moir
Timing is governed only by the point's gap, not the flywheel position. But flywheel position is important so it's been indexed to the crankshaft with a woodruff type key. There is no adjustment.
Have you got a puller that will work? I use the largest harmonic balancer puller I could find with three grade 8 1/4"-20tpi bolts:
F_R
Unless there is one of the small black wires shorted to ground, the flywheel has to come off and a systematic checkout made to find the bad component. There's no shortcut or magic involved.
boatingbob
O.K. are all the bolts on johnson flywheels 1/4 20 tpi? I don't wanna mess up the threads, and if so how long should the bolts be? Also if I'm going to pull the flywheel should I just replace everything under there? if so what are all the parts I should order, I finally got confirmation of my manual being shipped. Any advice would be great. thanks
boatingbob
Can anyone help?
Xcusme
Bob,
Buy 1/4-20 Grade 8 bolts approx. 4.5 inches. The 'parts' under the flywheel will be the point sets (2), condensers (2), and 2 coils. Inspect the coils for any cracks. Check and re-gap the points, per the manual.
If you had to replace everything mentioned, you'll spend approx. 75.00 depending on where you shop. The good folks here at iboats should have just about everything you'll need.
boatingbob
Xcusme said:
Bob,
Thanks for the help
boatingbob
Found my ignition problem: looks like it had the original ignition system from the time it was made. fortunatly for me the 28hp I had has an all new ignition system so I swapped it over, unfortunatly the weather turned bad so I was unsable to test the boat today. the following picture was my old coils.
