Re: Got my tilt/trim today..question...
Rich, here we go, when you finish the installation the three wires from the motor will effectively connect as follows, black to battery negative, red will connect to battery positive through one relay to turn the motor in one direction, blue will connect through the second relay to battery positive to turn the motor the opposite direction, only one color wire at a time can be connected, the relays will take care of this. You will need 2 SPST relays, that's Single Pole Single Throw relays with a 12 volt coil and 30 to 40 amp rated contacts. I got mine from the local car stereo/alarm shop, they use lots of these and they come with a plug in relay socket and wire harness. The relay terminals are apparently industry standard numbered, the terminal numbers you will use are 30, 85, 86, and 87. Number 85 and 86 are the relay coil connections, number 30 and 87 connect together inside the relay ONLY when you activate the relay by connecting terminals 85 and 86 to the battery. Connect the relays as follows, number 86 from both relays can connect together and then to the battery negative, number 30 from both relays can connect together and then to the battery positive terminal through a 15 to 20 amp fuse, number 87 from one relay connects to the red motor wire, number 87 from the other relay connects to the blue motor wire. Number 85 from one relay connects to the ON-OFF-ON switch on one end terminal, the number 85 from the other relay connects to the other end terminal of the switch, the center of the switch connects to battery positive through a 1 or 2 amp fuse. The wires from the switch to the relays and battery positive can be a small size like a number 16 or 18 since the current is less than 1/10 amp, the wires from the motor to the relays and from the relays to the fuse and battery should be as<br />large as the wires on the motor. I suggest you mount the relays inside the back of the boat assuming the battery is also there. Possible problem, one, when you finish and test the installation the boat motor may lift up when you want it to go down, if so then simply loosen the switch mounting nut and turn the switch a half turn and tighten the nut. I would also coat the relay terminals and relay socket with silicone grease to keep water out, that's about it, it sounds worst then it is really is, good luck. Any questions, just ask, good luck, Ken
