Re: Got the dreaded Volvo fuel pump whine. help!
ok, new pump is in. getting installed tomorrow morning. just a few questions
do i need teflon tape on the fuel lines?
will regular o-rings work on the high pressure lines or do i need something special?
this new one, the fuel filter is quite a bit longer and says it is a water seperator. I assume this is a good thing. can someone explain?
Ditto what Monster said. Never use teflon tape on any fuel system connection. Permatex makes an excellent teflon based thread sealant and should be available at most auto parts stores.
The shop manual says this about the o-rings:
"Fuel Pipe O-Rings
O-rings seal the threaded connections in the fuel
system. Fuel system O-ring seals are made of special
material. Service the O-ring seals with the correct
service part." I would attach the page, but I don't know how to do that.
Since orings can be made from Viton, Urethane, Silicone, Nitrile, and dozens of other compounds, I would suggest that you use the Volvo spec o-rings. They're fairly cheap and a fuel leak could "...ruin yer whooooole day"
The longer filter is an improvement by Volvo in their continuing effort to deal with the fact that more marinas are selling ethanol blended fuels which attract and hold water. It has more water separating capacity. If you can avoid ethonal fuel, do it.
