Got The Outboard Removed From Boat For A Milkshake
sphelps
Seacast can go quickly if your a fast and efficient termite ! :D
I used it not to save time but so it would never rot again ..
Woodonglass
Yeah, I would think it's not about the time as much as it is about the Rot and sometimes for some boats it's more practical.
64osby
Take a loot at archbuilder's Fuggly project, pretty sure he is doing a sea cast transom on that.
Might give you some ideas.
Ryanmolnar55
So the rain Is keeping me from moving forward today so ill just post pics of what I've done so far on this project. Can't have to many pic's
You prob. noticed a pic in there that had flooring installed. I had new flooring in and this spring when I uncovered the boat to start back up work on it there was a lot or water inside from a rip in the tarp that I used for the winter months. I have to redo all of that again the right way. Honestly i'm glad that happened cause had I not pulled the flooring out I would not have bothered the check the condition of the rest of the boat. I've learned a ton through the past year on restoring boats the right way so no more cutting corners. Hope you enjoyed the Pic's. More will come with progress.
Ryanmolnar55
Was unable to to remove the entire cap so this section has been removed to replace the transom. I'm trying to remove the inner skin as one piece to use as a template on the new transom. I looked into Seacast, it was interesting but the price was too high for me so I'm gonna stick with plywood.
