Got to get rid of a skunk...any tips
lakelivin
Re: Got to get rid of a skunk...any tips
This won't help you get rid of the skunk, but it might come in handy if there's an 'accident' while you try. My dog got sprayed a few years back & I used this; it really does work!
The mix was first created by a guy to neutralize the sulphury smell of a gas given off by chemical reactions in his lab (see bottom). When it worked, he theorized that it would neutralize skunk spray as well. He found a roadkill skunk carcass, treated it with the mix, and neutralized the odor.
Below is a 'cut & paste' of how to treat a dog that has been sprayed, but the mix should work for people or things as well. Hopefully you won't need it but you might want to make sure you've got the ingredients on hand just in case.
Skunk Spray Remedy
Usually dogs take a hit in the neck area. Typically they are sprayed while provoking the skunk and turn their head, while being sprayed, in order to avoid it.
First Aid
First check to see if your dog was injured by the skunk. If your dog is bleeding or appears to have been bitten, consult a vet immediately. Skunks may carry rabies. If vaccinated, your dog is safe from the rabies virus (but you are not!).
What you need
* 1 quart of 3% Hydrogen Peroxide, H2O2. Use fresh (unopened) hydrogen peroxide (H2O2). Hydrogen peroxide eventually turns into water (H2O).
* 1/4 cup of Baking Soda
* 1 teaspoon of Liquid Soap
* 1 pair of plastic or latex gloves
To Use
* Bathe the dog outside or, if it's too dark or cold, in the bathroom with the door closed and window opened.
* Combine the ingredients in an open container (do not store in a sealed bottle--it can burst).
* Using gloves, wash your dog with lukewarm water and the mixture while the mixture is bubbling. Work the mixture well into the fur.
* Be sure to concentrate on the area that was sprayed.
* Keep mixture away from your dog's face and eyes (it's a harsh solution). If your dog has been sprayed in the face, try an over-the-counter liquid douche.
* Let the mixture stand for 10 minutes or so before rinsing off.
* Rinse the dog with lukewarm tap water. Don't wash the mixture into your dog's eyes (use a washcloth to cover the eyes if you're rinsing the head).
* After bathing, check the dog's eyes. If they are red and watering, your dog may have taken a direct hit in the face. Skunk spray won't blind the dog, but it's painful. Contact a vet.
How it works
Paul Krebaum is a materials engineer. He was looking for a way to neutralize the sulphury smell of a gas given off by chemical reactions in his lab. He turned to his chemistry books, and reasoned that hydrogen peroxide could neutralize the smell by oxidizing the gas. The receptors that are in your nose are sensitive to sulfur in its low oxidation state, however they are not sensitive to sulphur in its high oxidation state.
Krebaum mixed together a few household ingredients and came up with a formula that deodorized the hydrogen sulphide gas. Hydrogen peroxide and baking soda, when combined, become a "chemical engine" for churning out oxygen. That's why it has to be used immediately after mixing. The soap breaks up the oils in the skunk spray, allowing the other ingredients to do their work.
A quote from Dr. Caceci of Texas A&M University:
"Forget what you have heard about tomato juice--it doesn't work. Skunk spray is mainly composed of low molecular weight thiol compounds. ("Thiols" are compounds with the "-SH radical" attached to a carbon atom.) In industrial applications, alkaline hydrogen peroxide (H2O2) is used for scrubbing similar compounds from waste gas streams."
I never tried it, but I'd think that an oxygen bleach (like Oxyclean) mixed with a liquid detergent would also work...
Joebklyn
I had same problem. Moth balls did'nt work so after trying all other ways, I called my brother up, he came over when we were not home and shot it with a .22 then picked it up with an inside out garbage bag. Glad I was'nt home feel bad 'bout that one
Bob_VT
Violence! Clubs, guns, bow and arrow.... too much violence.....:eek:
Do what what I did.....
Use a Havahart trap ..... catch the skunk.... cover it...... box it up ??? then I had a friend who worked at a Post Office and he sent the skunk on vacation to some empty house......
in Vancouver over 3000 miles away.... it worked!!!! :D:D:D:D
brother chris
Haha...yeah, thanks for the box Bob. You're freakin hilarious. LMAO!!
lakelivin
Don't know if it will work, but you might try fox or coyote urine salt. You can get it at Amazon.com, about $15 a bottle I think. Make small balls using a cut up stocking & place them surrounding the shed when you know the skunk isn't in it. The salt doesn't stink like liquids, so at least it won't make the shed unbearable to be in. Although, if it sprays I'm sure that will be worse than any repellent you might use...
Scoop
I have had a skunk hang around my house for the last 5 or 6 years. I have only seen it once, but smell it a couple times a week during the summer. The smell is so strong you know it has to be close, but it always stayed out of sight.​
I would say that cutting the long grass won't work since my house is in town and all the yards around are mowed regularly.​
Luckily I don't have a dog to corner the skunk.​
If you are worried or it becomes a problem, call animal control and see if they will trap it.
Of course maybe my advice stinks​
ANIMAL
Two words will fix your problem "PIT BULL". When its his yard ain't no skunk gonna set foot in it. Just don't get one that has been inbred plus you won't have to worry about some perv grabing you kids or burglers in th back yard....ANIMAL :D
luckyinkentucky
I'm a Wildlife Biologist by profession, so maybe that will give me a little credibility in this situation. :)
I run across skunks all of the time, and have been sprayed at least 3 times that I can think of. The best way to get rid of the smell is to take a bath in a mixture of tomato juice mixed with baking soda to make a paste. You have to let it dry on, and when you are done wash off with hydrogen peroxide. After the peroxide bath you then wash off with a detergent soap like Dawn or Palmolive. Suds it up really good, and rinse with COLD water. The cold water causes your skin to tighten up, and expel the remnants of the odors.
Butyl Mercaptan and methyl-1-butanethiol are what you smell when you 'catch a whiff' of a skunk. These 'proteins' resemble the same proteins that are responsible for decaying flesh, so that is why it smells so horrid.
Go to your local Wal-Mart or sporting goods store, and ask for a Predator scent. It should be very easy to find right now with Deer season coming in. Sprinkle a little around the perimeter of your home, and hope the 'polecat' gets the idea. :)
lakelivin
I run across skunks all of the time, and have been sprayed at least 3 times that I can think of. The best way to get rid of the smell is to take a bath in a mixture of tomato juice mixed with baking soda to make a paste. You have to let it dry on, and when you are done wash off with hydrogen peroxide. After the peroxide bath you then wash off with a detergent soap like Dawn or Palmolive. Suds it up really good, and rinse with COLD water. The cold water causes your skin to tighten up, and expel the remnants of the odors. . . . .
lucky, have you ever tried the solution I listed on the previous page? It's from the materials engineer who originally came up with the idea of hydrogen peroxide and baking soda to neutralize skunk spray. Sounds like it would be easier to apply and cheaper to make (no tomato juice to buy).
From what I've read it's the highly oxygenated mix of peroxide and baking soda that interacts with the skunk spray and changes the nasty smelling compounds you listed (types of 'thiols') from low oxygen types to high oxygen types which don't smell nasty. The detergent doesn't work on the scent directly, it just breaks down the oils in the spray so the peroxide/ baking soda mix can get at the thiols. I'd bet that the tomato juice probably contributes mostly by making the baking soda into a paste that will stay on until you add the peroxide. Everything I've read indicates that the only thing tomato juice does is to cover up the skunk spray, not get rid of it. Also, it seems like it would be more efficient and more effective to mix the ingredients all together rather than apply them sequentially....
Like I said, I've only had one skunk experience, but using the simpler process worked great. After I treated my dog with the listed mix I couldn't smell skunk at all unless I put my nose within 2 or 3 inches of his fur, and even then it was just a faint trace. And even that faint trace may have been because I couldn't do his head as thoroughly as I'd have liked to because I didn't want to get the solution in his eyes.
Thought I'd throw this out cause it sounds like you may get hit again (and again, lol). If the simpler process does work as well, seems like it might save you a little bit of time and money. . .
Either way, good luck with your next skunk experience! :)
Limited-Time
lakelivin's spot on with his skunk wash, if it comes to that. Have used it several times and it works like a charm. Although one time it took a couple of washings to completely rid the dog of the smell.
rentalguy1
Wolf ****? Maybe your own?
Either of these will work. If you use your own, collect it in a (mason) jar and let it sit for several days prior to "marking" territory. Pour it in small doses all around the area where the skunk goes, and around any flower beds. This will also work for any other nuisance animals...domestic and wild. As far as animal control goes, they probably won't be able to do anything, but they probably can give you the number of someone who can...my wife has been an animal control officer for many years.
Good luck!
beerfilter
I generally leave them alone , however , I do occasionally use a .22 to reduce the population every couple of years .
Not an option in most suburban neighborhoods , but you could use a paintball gun or BB gun to discourage them .
A nieghbor once tried an rc car to discourage skunks .
They were frightened at first , but , eventually just ignored the thing .
It was good entertainment , anyway .
Mothballs can be effective , but work best in crawlspaces , or , underneath sheds .
I once advised a family friend that she could put a "few" mothballs under her deck to discourage snakes from residing there .
A week later I came by for a visit and her ENTIRE YARD looked like it had been through a hailstorm ! :eek:
You could get a " skunk hound " , but you will be living with the smell just the same .;)
I once got "trapped" in a shed because the owners dog (skunk hound...) , cornered a skunk by the door .
The end result was a truly horrible mess , as the shed was unendurable for several weeks , the dog was PERMANTLY endowed with that same wonderfull aroma , even the grass where the dog rolled after the unspeakable encounter reeked for a month .
I had to be let out of another door that was used for loading trucks , it was latched from the outside.
I have stepped on them in the middle of the night , while walking through the yard . Tomato juice and baking soda does work , but , takes several washes for clothing .
One night my boss and I were coming back from a call .
As we came down the street close to our office , there was the usual herd of stray cats , along with a striped imposter , lurking in front of this little fitness center (closed at this late hour).
My boss pulls the truck up to the front of the building , cornering the imposter right by the door .
He then blows the horn and flashes his lights .
Completely panicked , the poor skunk deploys his only weapon .
ALL OF IT !
We both felt little remorse for the fitness center patrons , as they all had the same method for crossing the street as the skunk ( pay no attention to them big metal things , just walk right across ...) .
The place reeked horribly for weeks , despite many wash downs with power sprayers .
The # of clueless jaywalkers was temporarily reduced .
The owner finally quit feeding the stray critters , after the health department citation .
Ironically , SHE had called the health department about the skunk problem LOL .
jasonh
My black lab managed to get sprayed during a walk down to the creek. She was exploring a large concrete drainage pipe and unfortunately disturbed a skunk and her kits. I screamed at her to come, but her curiosity overrode her obedience and she galloped towards the defensive skunk. It was over pretty quick.
The dog (and our backyard) smelled for months.
I remember our vet giving us some stuff to wash her in, but it honestly did not seem to do anything.
_brad_
I highly recommend these as a last resort for most home/farm pests problems.
I feel pretty confident you can be shed of that skunk without it coming to that though.
Bingo; right to the head.
aspeck
It's hard to beat a good outside cat or two.
I sure would like to .... have one that keeps coming around and using my mulch as a liter box - and it sure does stink! He shows his face when I have the .22 or the bow out and he is history ... wife is ready to beat it to death with a broom. Neighbor state trooper is looking for it also ;)
moterboat
Skunks make excellent pets,you just have to have the scent bag removed..
Philthyphil
I have captured skunks several times in live traps. So far have not been sprayed. As mentioned, cover the trap with a blanket, move slowly. Skunks are usually not aggressive or mad like coons. My live traps have a door that will open when you turn the trap upside down. So transport the skunk in the trap all covered up. Get to where you want to release it. Turn trap over on side slowly. Wait a few mins and turn upside down, slowly, uncover door and tickle it down. Give skunk a couple on mins and it will saunter away peacefully. Now I don't do or recommend this but you can kill a skunk, coon, cat or your nieghbors dog very fast with this trick. They won't make it 10 yards. Open container wieghted down, can of coke, handfull of flytox fly bait. Mix coke and fly tox, like anti freeze, animals seem to really go for this. They drink this like mad and it just kills them in a couple on mins. I do not do this or recommend anyone do it. we have comerical sweet corn growers who can be wipped out in a couple of nights, of acres of corn by coons. Thats where I heard this trick, cruel but they have to make a living I guess. Still I would not do this but I'm not under attack.
My sister has several outdoor barn cats and a skunk often comes and eats cat food with them. They must think hes just another cat.I say never kill an animal unless you have too. Skunks do often carry rabbies as well as racoons but try to scare them away before you just start shooting.
brother chris
Well, I finally moved in a couple weeks ago and there is no skunk around anymore.
Maybe he could feel it in the air....that something was going to happen to him.
Thanks for all the tips...I have a few ideas of what to do if he comes back around....hehehe.
Cheers,
B.C.
