Today I finally had a chance to put the boat I bought a month ago in the water lol. It's a 94 Aquatron 1800LX with a 3.0. I had to put a fuel pump on it, rebuild the carb, lube all the cables, adjust this fix that and so on. Found the trim gauge only works partially, say when it's all the way up and as you lower the gauge stops moving around the 3/4 up mark. Any ideas? The speedo doesn't work quite right but I'm not even concerned with that. The RPM gauge works but when I put it full throttle, though it was a very short time, it only got to around 2500 on the gauge. Weird thing is, it was just me and a buddy and we cruised planed out with gauge showing only 1200 RPM or so. I'm not sure if the RPM's would've climbed the longer I held it WOT but this is my first boat and honestly was a little timid. I took the boat out with just me and my buddy to make sure all was safe with the boat before the family went. The admiral wasn't too thrilled about it but thankful when I sent her a video of the gas leak. The new fuel pump apparently has a hairline crack in it which we found after running for about 30 minutes, I was not happy. Got to go outside now and pull it back off and go swap it out. Also I was more than a little nervous when I crossed the wake from another boat and it was rocking side to side and bouncing lol. I actually backed off and trimmed in cause it spooked me. I'll get used to it I guess. Any tips for boating from y'all more experienced peeps out there would be great.
