Gray matter
hogtamer
I have a 15hp Johnson oyerhauled last year I troll with it all day, at the end of the day gray sludge comes out of the lower unit and it gets the tansom all oily The motor runs very good I was told this is normal I say BULL Iuse TW3 oil 50 to 1 Is there a gasket bad ? Some days alot comes out,other days not much.
12Footer
Re: Gray matter
Where does this gray oil come out at? Behind the prop? Out of the exaust ports?<br />Idling all day will create abnormal amounts of unburnt fuel/oil mix. It should noramlly foul the plugs more often than usual too.<br />Impeller wear is higher then normal if an outboard only idles. This is due to the vanes making constant contact with the pump housing walls. Not a biggy, but the impeller is a wear item to begin with, which is why I brought it up.You may want to change it every season.<br />To make sure your lower unit is ok, check it at the vent screw,using a pipecleaner like a diptick. IT should be full to the top, and translucent olive green,or brownish green.<br />If it is gray, you have a bad seal in the lower unit....Either prop seal,driveshaft seal, or both. Always remove the old screw gasket, and use a new one each time you check it.
JB
Re: Gray matter
Hi, Hogtamer. How much throttle are you using to troll? Most 2 strokes hate to idle under light/no load for long periods and will load up the exhaust with unburned oil where it mixes with cooling water to make a grey or brown (UGLY STUFF!!) sludge. That stuff looks a lot like what you will get in your lower end if water gets in there. Had that problem years ago and solved it by (surprise!!) using a smaller motor (2hp) for trolling. By working harder it ran cleaner.<br /><br />Smooth waters.<br />JB
ODDD1
Re: Gray matter
yes is what used to be premix oil/fuel....try running the kicker wot before you shut it down to clear out some of it.....
