nastyquedawg
Thread starter- Joined
- Dec 25, 2008
- 89
Sunday I took my boat out and ran it all morning. About midday as I was coming back in to the dock it started losing rpm's. When I brought the motor to idle and tried to take off again i could not get the motor to go over 3,000 rpms. So I get it loaded, take it home, check the fuel pump and noticed a gray like gasket substance all over the fuel pump screen filter. I was told that it could be coming from the fuel line because the ethanol is the gas can deteriorate the older gas lines. Does this sound accurate or do I have bigger problems? I did put in a new screen and ran some engine tuner through the engine. Had not had it on the water yet since I changed the filter.
