kingsfisherman
- Joined
- Feb 22, 2006
- 105
Was the bearing or is this the first time trying to grease a new to you boat?trying to grease the gimbal and it's coming out by the hole, did I miss it or maybe the band spun around?
thanks Brich for your reply, it is greaseable and I will pull it out and replace to try againDid you spin the bearing as you pumped in the grease. Is it possible that it is full? By the pic, I would guess that your passage into the bearing are not aligned. Are you sure that the bearing even is greaseable. The newer ones are "maintenance free" and are not greaseable.
thank you alldodge for your reply, same old boat new greaseable bearing,. gonna pull and replaceWas the bearing or is this the first time trying to grease a new to you boat?
Sealed bearing maybe![]()
Ayuh,...... Before ya do that, that's the outer race, that gimbals,.....thank you alldodge for your reply, same old boat new greaseable bearing,. gonna pull and replace
