Grease your alpha1 - But how much ??
Gods Favor VIP 1800
If you have to grease your out drive , pivot points, Gimbal bearings, etc.
How do you know how much is enough? 1 pump from the grease gun?
2 pumps? Or when you see grease coming out? Can you over grease it?
Any help would be awesome !
Your old friend the sea hag!
Gods Favor VIP 1800:):):p
Bt Doctur
Re: Grease your alpha1 - But how much ??
mostly untill you see it from the hinge pins, upper and lower steering yoke.
pull the drive to check the grease going to the gimbal bearing .
Why?, because you also have to grease the U joints and the input shaft. Not to mention checking for drive oil leakage or water intrusion into the boot.
Gods Favor VIP 1800
Thanks , will be checking it out soon ! I'm working on a design for a alpha 1
cable operated removal/installation cart . Will allow complete support for the whole project start to finish. should be ready to use soon . Will have pictures.
Thanks for your help doc
Sea Hag
Gods Favor VIP1800:):):rolleyes:
