witenite0560
Thread starter- Joined
- Sep 6, 2008
- 216
I was putting my lower end back on and needed the big rubber gasket that goes between the lower unit and the inner exhaust housing (1970 115hp Evinrude). Unfortunately, my boat guy didn't have one. But, he told me to go to the Auto parts store and get some stuff called Great Stuff gasket maker. He said he loves it! So, I did and it seems to be.... well, Great Stuff! It comes in a aerosol can with a plastic screw on tip and costs about $15. It says on the can that it will make 8 - 10 standard 4 cylinder valve cover gaskets. So, should make about the same number of lower end/exhaust housing gaskets. I was a bit concerned with how it would hold up to exhaust temp. But, it's good up to 500 degrees and the boat guy said it's worked great for him. It has about a 5 minute working time, so you want to put it on just before you assemble.
One word of caution, I'd be careful about using it where it might squeeze out to the inside of oil wetted or coolant systems. Use sparingly in those situations, so you don't end up with a lot that squeezes out and could potentially come loose and block passages and such.
Oops, my bad, it's called "Right Stuff", not Great Stuff. Sorry.
