Green gear oil in bilge, where does it come from?
liquidlew
Found a small puddle of green gear lube in the bilge right under the motor/oil pan. Cleaned it up and I can see it's dripping from just behind the engine. Tried to get a mirror up in there but just can't see it. I know gear oil goes in the bottom of lower unit and I thought it stops up at the oil vent hole. Does it go into something thru the transom into the engine area? I checked drive oil level and had to add maybe a half cup. Oil in drive and in puddle is clean, no water. What is leaking and I suppose I gotta pull the drive (or more) to get to it?:confused:
xltier
Re: Green gear oil in bilge, where does it come from?
probably coming thru the ujoint bellows from the seal next to the ujoints in the upper gear case.
Ayuh,... Pull the drive,.. The bellows is probably nearly Full...
