Grinding anode to make prop fit
jonny rotten
So I picked up my new prop and the tips hit the anode by about a 1/2 inch.Im going to grind it down for now.Needs replacing anyway.How much does the prop flex and how much clearance should I leave between prop and anode so when Im cruising theres no chance of hitting it?
jonny rotten
Heading out to test er out.I got it to about 3/8 space.Hopefully that enough
Starcraft5834
or, of course you could put a flat anode on.... I had the same problem, ground one down for clearance, then put a 4 blade on with a flat anode, noticed zero problem steering.
jonny rotten
Good to know,will put one on over the winter
Ayuh,..... Have ya got P/Steerin',..??
If not, ya might need the torque tab,...
Rick Stephens
Cutting a notch out works fine. No need to replace with a flat one. And like Bondo said, you might need it.
