I've got a 4.3l Merc I/O with an Alpha outdrive (1995). When I put the boat in forward the first couple of times I grind gears. It doesn't grind after I've been out for 10-15 mins. It's really just when I'm pulling out of my slip. Also, when I put the boat into neutral, the prop still spins a little in reverse. The shifter cable is about 3 years old. The grinding started last year.
Is this something that can be adjusted, or does this mean a new shifter cable?
Tom
Tom
