Grinding sound
GetRdone
I have a 1997 Wellcraft with a 5.7 volvo penta outdrive cobra sx.The problem I have is when I turn,it makes a grinding kinda thumping sound more when I turn it to the left.I had the outdrive taken off and they said the u-joints were fine and gimble was changed resently.I bought the boat 7 months ago and I just got back from a 2 week vac. on the lake and drove it every day pulling tubes and riding.I did like 5 hours a day and I was waiting for something to break but it still runs great.I put a new prop on while I was up there too .Any help would be great!!This site has helped me in the past so I hope for some good help again thanks in advance for any help!!
Don S
Re: Grinding sound
Replace the ujoints. I didn't say check them, replace them. When you take them apart, you will see the grooves. I have changed many that felt good, but looked horrible when taken apart.
Just the nature of the beast.
GetRdone
Re: Grinding sound
Thanks I will do that I told the guy to change them but he said they were fine.I think he was trying to get out of doing it:)
GetRdone
Re: Grinding sound
Well I finally got them changed and I still have the noise..When I rev the engine in neutral at 1800rpm the noise starts and it goes away at 2300 rpm and when its in gear it starts at 2200 rpm and I can`t tell if it ever goes away.This was done out of the water of coarse.Any help would be greatly appreciated!!
a70eliminator
Re: Grinding sound
So you haven't actually put in the water yet to try some tight turns?
Don S
Re: Grinding sound
Sounds like you have a different problem now. Originally it was when you turned it, now it's at different rpms.
Was the alignment checked 0 and at 180? ?
GetRdone
Re: Grinding sound
Sorry guys I left that part out but It still makes all the same noises in the water:(I had just never tryed it out of the water.
GetRdone
Re: Grinding sound
Ok I took the outdrive off and ran it and the noise was gone:) could it be the gimble bearing?It looks new but I don`t know how to change it:eek:
