HI
Same 21 Hydrasport I'm trying to get up and running.
(pardon the rate of questions as I try to get a full days worth of projects rolling every other weekend and then the parts ordered and here and call the inlaws and we have a work day on the boat so its weird I guess)
Anyway there was what looked like a brass or bronze screw through the transom. Had a big disc on the outside low on the transom. I had to cut the bolt to get it out when pouring the new transom. It had what appeared to be negative wire leads bolted to it. IE #14 or so wires all black or green.
Is this a backup ground or a good thing. What screw to use to replace it with IF I need to repalce it. Hole is there in the glass so its no big deal to drill it through again if needed.
Thanks, Jeff
Thanks, Jeff
