grounding plug wires????
tarponator
When checking compression on a cylinder or when performing timing (timing light) on cylinder 1, Do you need to ground the other plug wires? Why?
KCLOST
Re: grounding plug wires????
Yes, If not it could damage the ignition system... Primarily the switchbox(s) or coils. <br /><br />For a compression test all you need to do is pull the safety switch...
tarponator
Thanks! Thought so...just checking....have a great weekend!!!
LubeDude
If you have a kill switch you can just dissable it and go about your test.
KCLOST
Kill switch, Is what I meant....
