Grounding problem?
Erk469
I was in the process of rewiring my boat and I found that my black wire in my wire harness was burnt in several places from the throttle to the end of the engine harness, surprisingly the motor turned over and nothing happened but my and the wife noticed a spark on the battery every time we started the motor. When I took the engine cowl off I saw that the ground wire was connected to the the starter with the negative battery cable....is that right? I just want to make sure.
