matt194
Thread starter- Joined
- Oct 30, 2007
- 124
My motor runs ok on the muffs but not in the water (it will die after idling for 5 seconds). I checked compression and all is good. I tested spark and it could be better. I suspect the grounding to be bad. My question is can bad grounding cause the motor to run on the muffs but not in the water? Will bad grounding cause a weak spark?
Thanks,
Matt
Thanks,
Matt
