- Joined
- Mar 8, 2009
- 43,905
Well bought this manlift some years ago cheap and ran real well, its just old, I need a manual but cannot find one. This post is what I went thru trying to find out what the issues were. The lift has a 4 cylinder air cooled Wisconsin motor, 12V, GM alternator
Original
Idle is smooth, power is good and ran real well, moved good (some issues not so much but not an issue with this post) no issues
6 months ago
Replaced fuel lines and fuel filter (2nd time)
Changed oil and filter
Replaced battery with AGM Feb/2016
Started up, idle good, get it over to where I let it sit for the summer, and as it approached it started to sputtering and unless I rev'ed it up it would die. Decided it was more then likely a fuel issue. Did notice the amp meter was not moving off zero
Now
Tried to start and battery was dead. Jumped started and had it running, idle was OK but not good. Tried to move it and it was running but not well. It was moving but died on the road not far from parking place. Jumped again and managed to get it back to spot and started checking other things.
Thought it was a carb issue so I filled carb bowl with carb cleaner. Disabled fuel pump, let it sit for a few then tried to start but kept it from starting so cleaner would be pulled thru jets. Jump started it again and things running better but still not good. Gave up for the next few days with ideas of what to do next.
This is what I had to go on, and know what the problem was, just asking what would you do next?
Original
6 months ago
Now
