Well after my third attempt to take the boat out and having it die (again) after starting to drive it to the dock from the trailer I took the boat home. It had fouled the plugs again (same thing it did the last 2 times). I leaned the carb out a half turn and had it running on the muffs in the drive for about 10 mins so it was up to temp (right in the middle of the green band) and running fine. Then it started sending black smoke out the exhaust so I immediately shut it down. I had some issues with compression a couple of weeks ago but got the boat running and it didn't seem to affect the way the motor ran once I replaced the ignition module. I was leaning towards the headgasket (and am again) when the ignition module issue popped up since I had low compression on 2 cylinders. I'll have to investigate more tomorrow but I'm open to suggestions right now. Any ideas? I'm beginning to think my boat is afraid of the water.
