pointsnorth
Thread starter- Joined
- May 1, 2005
- 2
I acquired a 60 HP Evinrude together with a Zodiac RIB & it has given me some problems.<br />First question what year is it: Type: VE60TLETD Serial # G 03240328.<br />When I got it, old gas plugged the carbs, so I took off all the carbs, soaked them & cleaned out gum depostits in the 3 carbs and cleaned out the 2 tanks, which are switched manually. Installed fuel filter / water seperator "downstream" from the tank switch. It ran fine on the muffs after that, but when I put it in the water it was gutless under load. Wouldn't even get on the plane. I traced those problems to an apparent pinch in plastic fuel intake manifold on one of the carbs. That fixed, it ran OK but compared to a Suzuki 65 I had before this, I never came close to its get-up-&-go. I suspect it has never run optimally for me.<br />The other day I took my first run of the season offshore here in BC. It had hesitated a couple of times when going WOT, but when eased in it came up to speed OK. I got into some huge ferry wake, jumped the wake & it bogged down immediately after that. Same old-same old: could iddle & start pushing the plane, but if you went to WOT, or even 3/4 it would bog down and stall. No way I could get back up the plane. Could be restarted but only idle / slow speed. Strong tell-tale, temperature was holding fine, revves up fine without load.<br />Any ideas?
