Hi all!
I have a 1973 Rienell boat (17' trihull) that had a 1973 135hp Evinrude on it. The 'rude died, and I replaced it with a "older" maybe 69? mercury 1100 outboard (110hp).
The Mercury performs terrible on my boat. It takes forever to plane, can't pull a skier, is very slow etc. However, it worked great on the boat it came off of (a 17' v-hull glastron).
I adjusted the trim all the way out and in and it doesn't fix the problem. Any ideas on what could possibly be the matter? I haven't figured out how to attach the tach yet, but it sounds like it's revving as loud as before once it planes. When the motor was switched over we didn't change any settings, just disconnected the cables at the control box and reconnected them again.
Of course 110 is lower horse power than a 135, but that Evinrude had terrible compression one badly scored cylinder, and I'm sure was running at greatly reduced power.
Could it be that some setting got changed,
Is it possible that my heaver trihull needs a bigger engine?
The back of both boats are similar, but maybe the motor needs to be raised or lowered?
Any ideas would be welcome!
Thanks!
Ted
Thanks!
Ted
