Guy has a used boat 4sale, what else should I look for?
markh28
There are alot of experts on here, and I am seeking their advice. I don't know a lot about boats but I know some.
OK here is all I know. The guy that has the boat doesn't know hardly anything about it either, and is not very mechanical. But...
Its a tri-hull, looks to me to be about an early 70's, maybe about 18'. Dont know what brand cause the plate that looks like it would have the brand/model on it is missing.
The front open bow has about 2" of water standing in it. The boat hasn't been covered in what looks like a few years cause the vinyl seats are cracked and are showing alot of weather, and there are some small trees growing in between the seat cushions.
Motor-wise, its a 4 cylinder inboard/outboard. I couldnt tell the make, but I know its a 4 cylinder cause of the 4 new orange spark plug wires on it (he didn't know the make or HP either). There are 2 carbs that are not currently attached to the motor because the guy was going to put kits in it, and never got around to it. He has them in his garage. The carbs have probably been off for a couple years at least. The motor compartment is and has been covered with the exception of about an inch gap between the motor cover and transom which is open because of something in the way keeping it from closing all the way (looks like a light pole or something). The motor has some dusty dried oil on the bellhousing(?) at the back of it where it connects to the outdrive.
The Outdrive is white with the paint flaking, has "OMC" stamped on top of it,and a number underneath that, which I cannot tell what it is because it is scratched up, but looks sorta like "115".
The prop and outdrive visually look ok to me, no signs of rust or any visible damage from freezing or dragging on the ground, just some flaking paint.
The bottom drain hole on the boat didn't have the plug in it so I stuck my finger in there, dug out some leaves and crap and some water started coming out, not much, just a little stream. But that tells me theres water in the bottom of the boat for I dont know how long.
The last licensing sticker was from 2003, the guy that has it has never had it out. Although he said be bought it from a guy his wife worked with and they used it to pull skiers. I do not know how long current owner has had it.
The trailer looks ok to me.
Now the questions for the forum members:
What more should I be looking for?
The guy is asking $800 and will probably go down some from there.
As far as my knowledge, I am pretty good with carpentry tools and mechanical tools, do alot of my own mechanical work, etc. Ive never done upholstery but I could learn or have someone do it. And Im not scared to work on it.
What do you think? Should I ask more questions? Should I walk away?
Looking forward to all opinions on this!
WizeOne
Re: Guy has a used boat 4sale, what else should I look for?
...what else should I look for?
Another boat!
....Should I walk away?
Run, don't walk!
The undercarraige (floor/stringers) will be mush for starters. Also the outdrive is an electric shift OMC which you really want to avoid. With the motor apart, there is absolutely no way to know what you are getting into with the whole driveline.
Plus IMHO the only thing a tri hull is good for is stability while sitting still. I would not take that boat if it were free. Let the seller look for another idiot. Don't you be one.
Just keep looking. I'm sure with the economy and gas the way they are, you will find a gem for not much more and you won't have to spend the big $$$$$'s and time before you can use it.
Oh, and be sure to keep reading this forum. It will help you know how to look at a boat in the future. It also would not hurt to find a knowledgable friend who could go with you to look the next time.
tysonnathan
there are better boats out there for the money... i agree with wizeone. all the wood in that boat is probably rotten...you will have a few thousand in that boat before its all said and done.
LORDY611
Ditto--WAAAY too much money for who knows what. Sounds as tho that boat isnt far from being yard art anyway. Watch Craigslist and you may be surprised what is available.
oops!
run away.......run far and run fast.....
there is many reasons......
1. the boat is rotted right out and probably should be condemmed
2. the out drive...(omc) is out of business...and you cannt get parts very easy
it is so bad ....in fact....he should pay you to take it.....
and thats just a start
ezmobee
Honestly, not being overly dramatic or rude....I wouldn't take that for free. A project boat needs to have something you can work with. A good hull or a running engine or be practically free.
bomar76
Go back and smack him upside the head for even thinking that pile of junk is worth $800....
oops!
i sure hope i didnt come across rude.....we just want you to know the extent of the disrepair of the craft......
for 800 bucks....you can find a really good deal on craigs list or other.
when you find one you like.....look for one that has been kept in the garage....
a boat that has been kept out side uncovered full of water, will cost approx 2000 to repair....and that doesnot include the motor/drive
mtnrat
yep at least $2000 to repair the hull, IF you know how or are willing to spend the couple hundred hours to repair it yourself. That boat sounds to me that it is worth less than zero. Nobody here is trying to be hard on you, they are trying to stop you from making a huge mistake. A boat that is not running and not properly sheltered quickly becomes junk. It is amazing how fast it happens. So even if it was run "a couple of years ago" it may never run again w/o hugh input of dollars and labour.
Good luck in finding another for your boating pleasure.p.
tashasdaddy
"run Forest Run"
Dreams of having a nice boat are free.............but making it happin can be very costly. I say an older aluminum boat is the only way to go. Dont forget aluminum is light weight and this will save on fuel cost.
drewpster
Six years ago I bought this tri-hull. I had to do some minor repair work including some fiberglass and minor engine work. The original cost was $500 and I started the engine before the purchase. The trailer is not original to the boat. I have about $300 in it.
The bimini was added later. Keep looking, you can find a better deal.
Ayuh,.... The guy is asking $1600.00 TOOO Much..........
Get Away for that pile of Headaches,+ Heartaches......
sea wolf
A scrap yard will charge you $800 just to get rid of it. Well, maybe not that much. But that's where it belongs. The junk heap.
markh28
Thanks for all the opinions I really appreciate them, and no, I do not think any of them were rude at all.
I wasnt real crazy anyway about the thing just by looking at it, and now I am better off for asking the question on this forum.
Thanks a million guys!
