seattle scott
Thread starter- Joined
- Nov 1, 2011
- 113
in order to get a socket on the nuts to remove from the valve body, in order to repair the valve body. So the lines are 1/2 -1.00 inch shorter. I am going to try to attach the shortened lines. To do that I need some info on flaring the ends and getting a tool to do so. What is the size of the lines ( 1977 135 hp - 4 lines) 1/8 or 3/16 and what is the type of flare I will be creating? I have seen a hand tool flarer for about $25, but want to make sure I get the right one given the size of line I am working with and type of flare I am making.
If I can't hook up the shortened lines, then do I need to make up whole new lines or can I cut them back another two inches and then add 3 inch extentions using a compression union ? If I need to make up new lines ( or add the extensions) what type of tubing or lines material do I need to get? Can I use some sort of brake line source and what is the old stuff made out of?
When I fill the reservoir I hear that 30wt crankcase non detergent oil is what I should use - correct?
