Desert_Bassin
Thread starter- Joined
- Feb 18, 2005
- 38
Ok, I have an OLD 1959 Larson, atleast thats what the title says, there is no plate on this boat anywhere. Its 14' fiberglass, the rise is very blunt, and the bottom at the transome is flat, with just a 1 1/2" keel, it has a strong running Evinrude 1962 v4 75 hp motor with a 9 1/4 X 10 prop, motor came with a hydrofoil attached. I've had the boat a few years now and have it nice and clean looking, it hasnt been ran much since I have been working on it. So I take it out for 2 days last week with the kids, total of 4 of us on the boat, while running at full throttle the speedo says 27 or so mph, dunno how accurate it is, old airguide, rpms were right about 5000.<br />(trying to give as much info as I can)<br /><br />Now for the problem, when running wideopen or theres about, the boat does not want to turn, the boat lists ALOT the more you try and turn, scary even, I have to make a VERY VERY wide turn at speed. I'm wondering if the motor is not setup propery as in too high/low, if the hydrofoil is causing it??<br />The motor only has manual tilt adjustments, which I'm sure most of you know, I have 4 options.<br /><br />I can provide pictures if that would help.<br /><br />Any tips and tricks would be greatly appreciated.<br /><br />And you prolly wonder why I would want to deal with an old boat.... it looks great hooked up to the wifes pink 59 Caddy
<br /><br />Thanks again!
