Hard Lime Green sealer/Filler (?) on Exhaust Manifold
KM7
91 5,8 Ltr OMC/Penta V8. I'm changing the Elbows/Risers. I was overheating only on the port side. See other post
I'm cleaning the mounting surface on the top of the exhaust manifold where the gasket will be, and on the port side there is a very hard sealant or something. BTW, that is the side that was overheating. The sealer/filler (?) is lime green and comes off with a lot of scraping. Could it be a filler used to repair the gasket surface? Maybe I should not be scraping it off!!! Any thoughts?
I was going to use a sanding block to get everything clean and smooth, but I will wait until I hear from a few of you.
