stepheneff
Thread starter- Joined
- Oct 26, 2020
- 2
Got a 76 merc 20hp not running. Found the ignition wiring burned up so I replaced the electronic switch module and repaired the trigger. Now I had spark on both plugs. Figured that was the problem, so I put things back together. With spark plugs out the motor turns easily. When I put in the plugs I can barely pull the starter rope. Can get it to turn but very hard. What is going on?
