Since i brought my boat to the local marina and replaced the pump in the out drive shifting and starting have been stubborn. When going forward I have to pull the selector lever past neutral slightly into reverse to go into neutral and vice versa. It's also become stubborn to start, I have to have the selector lever at just the right point before i go into neutral for it to start, like an interuptor switch problem. Could both of these come about from an impeller change?
Also i noticed a black wire with ring terminal just hanging loose in engine bay, I followed it to the connector plug mounted on the port side riser, it is the bottom wire of the connector? any help please.
Thanks
Thanks
