hard shifting
glasstream86
i go to push the throotle forward and the motor revs up pretty high then i hard thud like the gears catching and then it goes into gear. could this be a shift cable problem or is my lower unit goin out? any help or advice would be greatly appreciated
SLiM JiM 156
Re: hard shifting
Try unhooking the lower shift cable and see if it moves freely, if it does try moving the controls with it still unhooked, if its still stiff try removing the cable from the controls and moving it. That should isolate it.
180shabah
Re: hard shifting
Sounds like you have a cable issue. The throttle should not open before it goes into gear. You need to get this corrected before any damage is done to the drive.
It would help to know what drive we are talking about too.
D
DJ
Guest
Re: hard shifting
You are probably in the wrong area.
What type of engine?
Outboard or I/O?
Once known, go to the appropriate engine section.
Thanks.
glasstream86
Re: hard shifting
it is a cobra outdrive that hooks up to a 4.3 l cobra motor
D
DJ
Guest
Re: hard shifting
There you go, I will move this to the I/O section.
Post there with the model year.
Thanks.
180shabah
Re: hard shifting
Click here for info on the cobras.
They are very sensitive to shift cable adjustment/stretch/binding - if not right, they eat thier own gears. A couple hundred dollars turns into a couple grand real quick.
glasstream86
Re: hard shifting
thank you for the webpage and history 180shabah i believe mine could be a king cobra the gears are on top and the water pump is located right behind them. i took off the upper case to change the water pump since my ears would not push enought water up to the pump and that is when i noticed the gears at the top this is my first boat so i did not know any better. do you have any more reading material so i can get more familiar with the outdrive i have
180shabah
Re: hard shifting
Go to the top of this (I/O) forum and click the adults only link, scroll down to #12 OMC Information - you can get a pdf manual, it's not a factory manual but it is free. There is also alot of great general maintenance info in that section.
glasstream86
Re: hard shifting
ok one more question is there any special procedure to adjusting the king cobra outdrive or will it be in the manual i am goin to download
180shabah
Re: hard shifting
It should be in the manual, but having never owned a Cobra, I've never actually read the manual....
