hard start and buzz noise
jlams73
I have a 1978 Evinrude 85HP and it is hard to start but once started it runs for the rest of the day. This weekend I noticed when I tried to start, it will crank like usual and when it is about to start (1/2 of a sec) it will immediately make a buzzing noise. I will have to try to crank a couple of times and it will buzz each time. Then it will finally crank and fire up. What would cause it to make the buzzing noise? I have already replaced spark plugs. The old ones were fouled and way out of gap. I was hoping that was the problem but did it again after the new plugs was installed.
Al-53
Re: hard start and buzz noise
where is the buzzing coming from...if under the motor cover ..remove it to see it the bendix is rising to engage the fly wheel....they make a buzz if the are stuck....if its stuck try to spray it with a little brake cleaner or carb cleaner to break the junk up....then oil it with 3-1 oil.....if it still does it u need to start to trouble shoot the starting system...
also make sure all the connections from the battery to the starter are cleaned good...shiny good...ground's also
Al
jlams73
Thanks Al-53 for your input.
The buzzing noise sounds like it is coming from under the motor cover, so I will check the bendix. If it is the bendix, will it do that every time the motor cranks up? Because, once I get it fired up, I can stop and start the motor rest of the day with no further problems. Knock on wood...
Al-53
if u clean and oil it right it should be fine....some oils gum up and once warmed they loosen a bit....so clean it with a spray type cleaner..no need to drench it just a couple quick shots of say brake cleaner....the click the starter a couple times and then oil it..like I said 3in 1 oil works great..does not gum like wd-40 will.....just 2-3 drops of oil is fine...check connections also....
Al
jlams73
Thanks, I will do that tomorrow!
