Hard Starting 15hp
6bull
Hello to the forum.
I have a 1979 15hp Evinrude, model 15904E. It is cold blooded, takes a few pulls to start, the problem is it is very hard to start after running and setting a few mintues to half an hour, it will start right up if I shut it off then try starting right away.
It takes about 15 pulls to start and that many cuss words.
I bought this motor used so I don't have a history on it.
I did back in November put 3/4 can of seafoam in a gallon of fuel then put the remainder in a squirt can which I sprayed in the carb while it was running.
Should I check the screen in the fuel pump, kit the carb or could it be a spark problem?
Your suggestions are appreciated.
Jim
crxess
Re: Hard Starting 15hp
Do you choke it on attempted restart? I found my motor needs the choke after 10-15 minutes off. Fires up easily that way.
Choke helps pull more fuel to air into cylinder and reduces vaporization(evaporation)
ondarvr
There are a few possibilities.
First check for spark when you can't start it, when the motor sits for a few minutes after running the heat from the block can migrate into the coils and cause them to fail.
Rebuild the carbs.
Check compression, low compression can create hard starting.
6bull
I will try that next time I'm on the lake. Thanks for your reply.
Rebuild the carbs.
I ran the motor in a test barrel for 15 minutes, then used a spark tester, nice blue spark. I then did a compression test, it showed 110 psi in both cylinders.
