utah boat owner
Thread starter- Joined
- Nov 18, 2012
- 24
I have a 71 9.5 that has always had trouble starting, since I got it. I was using starting fluid to get it going, and was yelled at by many of you for doing so, but couldn't get it going any other way. I have replaced plugs, put in a carb kit, new points but still couldn't get it going without starter fluid. So all last summer I used starter fluid to get it going after which it would start all day with one quick pull of the starter cord. Someone suggested I visit Leroysramblings to set points which I just did. After all this I still can't get it running (I didn't use starter fluid), but pulled a plug and noted it was dry. I would have suspected it to be a little wet. I haven't messed with the fuel pump thinking that it was OK in that I can pump the bulb till hard, and once running, it will pull gas fine.
I'm getting frustrated in not being able to fix this hard starting problem. Please help!
